Engine harness
nakabrd
I am installing an new M&H engine harness on my 1970 Challenger. There is a connection near the coil that is a blue wire with a rubber covered female pin style connector. I called the Technical Support at M&H and he said it goes to the distributor. The only wire that I'm familiar wire from the distributor goes to the positive side of the coil. Does anyone know where this wire goes? Thanks for your help, Jeff
Thanks Detmatt1 but I found the temp sending wire. This blue wire comes out of the harness with the coil wires. It has a straight rubber piece covering the female pin style fitting, not angled like the temp sending connection.
Thanks leo but the oil pressure switch is near the firewall at the back of the block.
Is it a lug or round bullet connector it could be the electric choke wire
I haven't seen a stock connector other than this one for electronic ignition.
It's a points ignition, not electronic. Part number of the engine harness is #00220.
