1969VADart
So as I am beginning to remove the damaged body sections on the back of this car, I have a number of questions. The most important is based on these couple of pictures, where should I be looking for the spot welds that hold the tail panel on? I noticed in looking for replacement parts, there is a filler strip that joins the tail panel to the trunk. I assume that is on the bottom of the panel. I will also be replacing that damaged trunk gutter on the passenger side of the car. Is it best to drill out the spot welds, or should I look to grind them down? I am no body man so any advice would be appreciated. Thanks.
