ldr
1970 hemi engine complete -casting date 11/11/68 . the engine is apart for your inspection, all machine work completed and all parts are either new in their perspective boxes or reconditioned. machine work completed list as follows; block BOILED, deck squared, bored .020 thousandths over, threads chased, new cam bearings installed , crank is 10/10 , rods have resized and rebushed , arp rod bolts installed, pistons are hypereutectic .020 , rings are speed-pro and have all ready been file fitted to the bore, the entire rotating assembly has been balanced. heads virgin uncut heads with the exception of gasket porting, a 5 angle valve job , and bronze wall guides installed. parts included: felpro gasket kit , Racer Brown custom grind hydraulic cam shaft with lifters and springs to match. Bronze distributer drive gear , melling high volume oil pump, arp head bolts and studs, wide pad rockers, mopar push rods new old stock oil pick up tube, original correct intake , correct 1970-71 valve covers , matched and date coded 1970 hemi 4spd carbs and rebuild kits, new engine bolt kit ,throttle cable bracket, return spring brackets, throttle springs, original oil pan and balancer pm here for phone number. $30,000.00
