7DCUDA383A
I have the Carter 383 fuel pump , the 5/16 outlet points right at my radiator hose , do they make a push on 90 degree adapter for these so I can direct it the opposite way .
I have heard about those but does the psi matter , I think the one I have is 6 psi and the others at 8 psi , if I'm wrong let me know , I'm still learning .The Carter M4589 on your 383 is the correct style for a 1969-1971 383. However, your engine has the 1974-1978 water pump housing which has the inlet on the passenger side that interferes with that fuel pump outlet line routing. A 383 originally had the water pump housing with the driver side inlet, used on 1958-1973 big blocks, such as the one in the following image:
To keep the housing without fuel line interference and without using adapters, use a pump from a 1974-1978 400 application and matching outlet line, such as the Carter M6935 shown in the following image:
Alternatively, use a pump for a 1968 and earlier 383 application such as the Carter M3672 shown in the following image, although there is a little less clearance with this one than the M6935:
The Carter 3672 should be good for my 383 then .PSI does matter, but the range of these pumps is within stock specifications for stock type carburetors.
Carter specifies the fuel pumps as follows:
- M6935 at 4 - 7.5psi ( Carter M6935 ).
- M3672 at 4 - 5.5psi ( Carter M3672 ).
- M4589 at 4 - 5.5psi ( Carter M4589 ).
The earlier pump is the same pressure as what you have. The later pump is a little higher, but unless your needle and seat is weak, it will work okay. It's specified as a stock replacement for the later 400s with stock carburetors. For an aftermarket high performance carburetor, the pumps will work okay as well. Other brands of replacement fuel pumps may vary a little, but should be close to the Carter numbers.
I was looking for a rubber 90 degree or something like that , I'm just gonna run it up to a filter and go , it isn't that bad of a bend , and yes this cuda was a cludged build , whoever that was is an ***hole .I bought the pre-moulded hose to use on my 98 Dakota a few years ago. A section of it might work for you cludged together 383.
Me too and will do , thanks again .As long as it runs and you can enjoy it is the main thing at this point. E-Bodies are definitely an "E" ticket ride. I can't wait until you Cuda is running well and you give us a report!
I am putting a heat shield sleeve over it , I know its not proper but I really dont feel like changing the pump right now , next winter I will do some more work .You don't really want the fuel hose resting against the coolant hose heating the fuel !
