American autowire 12V supply during cranking
northstart
Finland
Hi fellow e-body gearheads,
I have installed AAW wiring harness 510289 and Holley Sniper EFI to 1970 Challenger.
I have difficulties to find a 12V supply which is hot in "Run" and "Start" keyed ignition switch positions. Car does not start without 12V during cranking. Power leads in the harness and fuse block IGN spades seem to go off during cranking.
Comments and instructions would be appreciated!
This might be a start. 71 Challenger Assembly starts
Not knowing anything about the AWW. @Todd Jackson and I went through the wiring. This is the results that we came up with. Todd Jackson would be more versed about this wiring harness. He would have the final results for the applications. I'm more then willing to help out where I can.
So you needed to cut the plug from the switch? This is what it should be on the new turn signal switch to the AAW wiring colors. That your showing me. A better picture of figure E would help.
MOPAR turn signal Switch colors---------- After market Switch colors-------------AAW wire colors
Stop lamps-------------White -----------------White------------------------------------White
L F turn signal --------LT Green--------------GREEN ----------------------------------Light blue
R F turn signal -------Tan---------------------Yellow/ Blk Stripe ------------------Dark Blue
Emg Flasher ----------Pink-------------------RED --------------------------------------Brown
Turn signal Flasher--Red---------------------BLUE ------------------------------------Purple
L R turn signal-------Dark Green----------- Lt Green --------------------------------Yellow
R R turn signal-------Brown-----------------Yellow -----------------------------------Dark Green
Horn relay------------Black-------------------Grn/w-----------------------------------Black
AAW wiring. So you needed to cut the plug from the switch? This is what the colors would be on a new turn signal switch. The AAW wiring colors. Figure E. The Mopar wiring colors. My opinion: If you have the the car side of the turn signal sw plug. I would cut it with enough wire to remove the insulation. Then soldier the AAW wires to the plug wires and have shrink tube on before soldiering. Or get one. That way you retain ease of replacement and or trouble shooting. They are low current.
Turn signal part.
As far as the start and run, I think they were tied together. I'm looking for the diagram. I thought it was posted here. Below is for 68 70 B body should be about the same. This might be of help. I'll keep looking. White 122, Brown 7 and pink 3A Is that what you need? I'm just shooting in the dark here!
northstart
Finland
As far as the start and run, I think they were tied together. I'm looking for the diagram. I thought it was posted here. Below is for 68 70 B body should be about the same. This might be of help. I'll keep looking. White 122, Brown 7 and pink 3A Is that what you need? I'm just shooting in the dark here!View attachment 140844
Thanks Challenger RTA. Otherwise AAW wiring works well (except fuel gauge shows full all the time but that's another story) and installation instructions were pretty clear.
I'll check the pink and brown!
northstart
Finland
I had same issue when I installed FiTech.
The answer was to add a diode, between start and run.
That way it had power when needed, and isolated the opposite direction.
Where to get 12V key on inc cranking for Holley Sniper EFI
Thanks for your input and the link. I forgot to mention that I have Hyper Spark ignition, so there is no ballast resistor.
Diode sounds a good silution. Just that I haven't used diodes before.. have to study a bit. I wonder what is the IGN2 in the AAW harness? Was also thinking about using a relay, do you think that would work?
Katfish
Palm Bay, FL
Either will work, diode is easier to integrate, small and cheap.
Tape it up in the wiring harness.
Look for a diode used in solar panels, handles power and has a low voltage drop.
Paul Wurtz
I have the same setup on my Demon. Holley Hyperspark ignition and EFI(no ballast resistor). I went the diode route. Wired the 12v switched wire to both the start and run wires with diodes. Works fine for me.
rmchrgr
Stamford, CT
A few years ago I had a '68 Coronet that I rewired with an AAW kit and installed a Holley Sniper. Here's how I get 12V in crank and run since I don't use a ballast resistor. This is a 1968 ignition switch which is in the dash but it's the same idea for '70-up switches in the column - installing a jumper wire between IGN1 and IGN 2 terminals will give you 12V in crank and run. I don't use a diode, the current won't back feed. You can do the same at the ballast resistor if you're still using one, just have to remove the resistor wire inside it and put a jumper between the ends.
After this, I created a dedicated 'buss' off the pink wire (ignition switch feed lug at the fuse box) for things that needed switched 12v like the pink Sniper "on" wire in addition to the Hyperspark ignition box and distributor.
MoparCarGuy
My Cuda's Holley Terminator X Stealth EFI wiring diagram. Added a main fuse, auxiliary main power relay to a fuse panel, etc.
This isolated the EFI from the factory wiring and bulkhead connector. Also, upgraded to a Powermaster 100A alternator.
northstart
Finland
THanks for sharing! Nice to see that it can be done in several ways.
I sent the question also to AAW tech support and this is what I got from there:
Good afternoon!
When searching for power during cranking and run, note that the original ignition switch setup most likely had a bypass wire. In this case, it was a brown wire which provided power to the ignition system ONLY DURING CRANKING, and then when the key was turned back to the run position, the pink wire took over.
The brown wire will be the unmarked 14 gauge wire and can also be found in the engine compartment wiring instructions as well
For power during cranking to the sniper EFI, take the pink and brown wires that usually route to the coil or HEI, and run them to the input wire for your Sniper and that should get you to where you need to be.
Let me know if you have any questions!
Good point. The ing sw when in the run position, is not feeding power to the start contact. There would be power feed back to the start wire but not through the switch contact.
I don't know the system you guys are taking about.
reason being. I would miss the sound of the Thermoquad. Some say there complicated but when you understand it. It's like an old friend you know.
The other is if I understand it correctly. Is the carb is better for performance and the fuel injection is better for mileage and reliability.
I like to think simple. It's easy on my brain cells that are left.
MoparCarGuy
I do not know if the in-tank Walbro fuel pump or the EFI system has a “rollover” feature. An extremely rare event that is no different than the old days of a Holley blue or Carter electric fuel pump. Even a mechanical fuel pump continues to pump if the engine is still running.
rmchrgr
Stamford, CT
When using any type of CD ignition a la an "MSD," you have to "tie IGN 1 and IGN 2 together" so this type of thing is nothing new. The Holley Hyperspark ignition is basically a re-badged MSD box and the Hyperspark distributor has an MSD logo on it. It's all the same stuff.
The best way to tap into an ignition-switched 12v source on Chrysler products is to do like I did and create a separate buss of the ignition feed wire. You can fuse it too. With the Holley EFI stuff, the pink wires are just low voltage triggers so fuses are not reuqired. The fuel pump needs a switched 12v to turn the relay on but the fuse goes in the main power wire.
Retrofit EFI systems, especially the Holley Terminator/Dominator stuff is every bit as good as any carburetor. To my knowledge, no one would use one if they didn't have to or were trying to prove a point. All the quickest cars at the drags use Holley EFI stuff now. Very few fast non-ECU controlled cars out there anymore. Even some of the carb guys use the software to control their igntion, data log and run sensors where allowed.
Question. Looking over the diagram you posted. Is there a roll over relay to turn off the fuel pump in that event? Or is it built into that system? Hope that never happens to any one!
There is a rollover vent valve supplied with the EFI tanks but not an ASD relay.
northstart
Finland
This issue was solved and now car starts and runs well.
I put unmarked brown wire (12V during cranking) and pink IGN wire together to feed ECU, CDI and distributor. I also have alternator which needs excite wire and had to put diode to stop the backfeed because otherwise car did not turn off.
Thanks all for your help! Hopefully this will be useful for other people in the future.
