Clutch ticking noise
KPB
Austria
Hi all,
After a drive where I occasionally used the clutch a bit more "firmly", everything still felt and sounded normal. I then parked the car for 1–2 hours, and only when setting off again did I notice a new ticking noise. At first, I suspected an exhaust leak, as I thought I could also hear it when standing next to the car, and it initially went away quite quickly as the engine warmed up. Later, however, it seemed more related to the clutch – appearing whenever the clutch pedal was pressed, from just lightly touching it to fully depressed.
  • Sound: “ting-ting-ting”, varies with engine speed
  • Sometimes disappears as the engine warms up, but not consistently
  • Can persist for a while, but also go away after a mile
  • Driving and shifting still feel completely normal
My first thought is the throw-out bearing, though I’ve had a defective one before that made more of a “howling” noise rather than ticking… so I’m wondering if there could be other possible causes. Any ideas or similar experiences?
Thanks in advance!
I have had the surface of the disc break away , I would pull the cover & inspect closely .
What brand , How new ?
KPB
Austria
Can't really say, came with the car, at least 11 years old..
Steve340
New Zealand
I heard a clutch make a sort of ticking noise once - it was a bent/cracked release arm of the pressure plate.
This clutch did work but was somewhat juddery when you tried to get moving from stopped.
KPB
Austria
Get moving feels pretty much the same as always; it’s only the noise that stands out. I still need to test it again next week — the last time I parked it in the garage, the noise disappeared. I also have a shop appointment next week so they can take a look, but it’s good to have a few clues I can pass along to them.
Just in case the entire clutch assembly ends up needing replacement... any advice on how to positively identify the correct parts? Are there any part numbers or casting numbers that can be seen through the bellhousing inspection cover? Shipping takes a while to get here, and I can’t leave the car sitting at the shop for weeks or have them pull the drivetrain apart twice. 🙈
You should have a 130 tooth flywheel so you need a 10.95" setup , the disc could be 23 spline [ more likely ] or 18 spline HD trans .
I would use McLoud or Ram or Zoom , Stay away from Centerforce garbage , I prefer to use factory Bog & Beck 3 finger type over Diaphragm type as the factory system is design
for the 3 finger type , throw distance & removal of the overcenter spring is usually different with Diaphragm type
KPB
Austria
It's probably a Ford or Chevy that got caught under when passing them.
Post a video on Youtube then post a link here. Someone here might know what it it.
Ok will try it but can only do by next week when going home 👍🏼
The reason why I'm asking is also because originally it was a 3 speed manual and I have no idea what had to be changed for the 4 speed. But let's see what is really needed in the end...
lainetx9
Arizona
I prefer the "Diaphragm" pressure plate over the "3 finger" type only for drivability, but not for racing. The diaphragm is a smooth action while depressing the clutch, and lets out smoothly as well. The 3 finger is pretty aggresive and harder to engage and disengage (unless your a muscle man with a strong left leg). I do have bothe styles in a couple of my ebody cars, and the drivability is much more confortable w/ a diaphragm style. That`s just my opinion. Thanks
KPB
Austria
As promised a video of the noise. Sounds even more grinding than ticking or a combination of both.
Thursday in shop...
KPB
Austria
Good that I have video evidence now. Car has been sitting here a few hours and now... Nothing. 🤯
