Chassis Parts Color Guide
Lunchbox
USA
I am getting ready to start having the below items powder coated/painted and wanted to check proper colors and sheen. I am thinking that anything that is bare steel will be painted to replicate that look. Some of the colors below were taken out of the Authentic Restoration Guide, Challenger & Barracuda Restoration Guide 1967-1974, would like to check correctness of them. Will add to the list with anything I missed and update this first post. Thanks in advance.
I'm specifically looking for a 1970 Hamtramck built car, but can expand as needed.
K-member - Semigloss Black
Valance Brace to K Member - Semigloss Black
Sway Bar - Semigloss Black
Front Torsion Bar Brackets -
Front Torsion Bar Retainer -
Torsion Bars - Semi Gloss Black
Lower Control Arms - Natural Steel Dipped in cosmoline to the outside rivet
Torsion Bar Adjuster Bolts and threaded Block -
Upper Control Arms - Bare Steel or Semigloss Black
Steering Knuckles - Bare Steal
Strut Arms -
Front Suspension Consumables (Tie Rods, Ball Joints, Etc) - Bare Steel
Transmission Cross Member - Semigloss Black
Shocks - Gloss Black
Leaf Spring - Semi Gloss Black
Rear Sway Bar - Semigloss Black
Shock Plates - Bare Steel
Leaf Spring Hanger - Bare Steel
Pinion Snubber -
6 Way Seat Under Floor Brackets -
Rear Tie Down Brackets - Bare Steel
Front Bumper Brackets -
Rear Bumper Brackets -
Valance brace to k member - semi gloss black
Upper control arm bare steel or gloss black
steering knuckels - bare steel
Struts - bare steel
Shock plates - bare steel
Leaf spring hanger - bare steel
Rear tie hold down brackets - bare steel
Since different factories did things differently, to be perfectly factory correct, you need to ensure you're using what was done at either the Los Angeles plant (70 only) or the Hamtramck plant.
I love the list! It will be a great reference source! Thank you for putting it together!
This is a B-body link, but perhaps similar
These were posted somewhere for a 1970 Challenger. Not sure who the OP was.
Great point I updated first post to specify 1970 Hamtramck built car.
@larry4406 great info what magazine is that from? Will take me a little time to pull all that info out and summarize it in the first post. Thanks!
It appears it was from Mopar Action. Link bellow lists it as from their Issue #7 of reissues.
Not sure where I originally snagged it from. I am guessing from Moparts way back when.
