MSD Blaster 2 Coil Question
ebodyman1
Ohio
My Challenger has the Rallye gauge package. It currently has the stock electronic ignition system and coil. I started to install an msd blaster 2 coil and a friend said it might damage the tachometer. Has anyone else heard of this? Thanks in advance.
You cannot run an MSD Blaster coil with a stock Rallye gauge cluster! So your heard currently. I would just run a regular coil or ungrade to an MSD ignition. The problem is the new MSD boxes are cheap ChiCom crap that fail. Therefore just use a stock type coil. Preferably a coil made in the USA if possible! If you can find an MSD made before 2000, you're golden. You run to tachometer off the MSD box and not the coil.
Never heard this before, why not?
If using an MSD coil in an otherwise stock Chrysler electronic ignition system, the tachometer is triggered from the negative (-) terminal of the coil the same as a stock coil. However, the MSD Blaster 2 series coils have a 0.7 ohm primary winding compared 1.4-1.8 ohm range of stock Chrysler coils. To use this coil with a stock electronic ignition system, use a 1.25 - 1.5 ohms primary ballast resistor instead of the 0.55 ohm primary resistor used with electronic ignition to mid 1975. Using the higher resistance resistor is to keep the primary circuit current at the same levels to prevent overdriving the switching transistor on the electronic control unit (ECU).
If using the original type four terminal, dual ballast resistor, the primary, or compensating, side should be 1.25 ohms. Original and early replacement dual ballast resistors had a 0.55 ohm primary side resistor (Chrysler part number 3656199). The primary resistors changed during 1975 to 1.25 ohms (Chrysler part number 3874767). Later Chrysler resistors and replacement units are typically 1.25 ohms, but should be checked for actual resistance.
If using a two terminal, single ballast resistor, ensure it is 1.25 - 1.5 ohms as well. Most replacement resistors nowadays are typically ~1.25 ohms, but it can vary.
A better match for the stock electronic ignition system if changing to an aftermarket coil is the Accel 8140 or 8140C:
Accel8140 Super Stock
8140C Super Stock
1.4 ohms9.20K ohms8140 = painted
8140C = Chrome
I have used the Accel 8140 for the last 30+ years with my stock or mostly stock systems. All are old USA production. Like MSD and other brand offerings made overseas today, quality and reliability might be in question though.
The following table lists MSD Blaster coils:
Part NumberPrimary
Resistance
Secondary
Resistance
Notes
MSD82000.7 ohm4.50K ohmsChrome.
MSD82020.7 ohm4.50K ohmsRed.
MSD820230.7 ohm4.50K ohmsBlaster 2, black,
MSD82030.7 ohm4.50K ohmsBlaster 2, chrome. Supplied with a 0.8 ohm ballast resistor.
MSD82220.7 ohm4.70K ohmsBlaster 2, black, epoxy, high vibration,
The following table shows original and aftermarket replacement resistors:
Chrysler
Number
Aftermarket NumberTerminalsResistanceNotes
2095501,
2196316,
2275590,
4106140
  • AC Delco C1101
  • BWD RU19
  • Carquest RUA1036
  • Duralast AL795, AR-17
  • E-tron RU10
  • E-tron RU11
  • Echlin ICR 12
  • Filko AR-17
  • GP GCR7
  • Kem FR56, FR56X
  • Niehoff AL125A
  • Prestolite 32-20
  • Standard RU-11//RU-11T
  • Valley Forge RU61 ???
  • Wells CR-107 or AL795
20.5Single, 1960 - 1972.
Metal strap, although some later manufacture might be with a molded mounting hole.
3656199
  • Accel 150351
  • AC Delco C1102, 12309766
  • Airtex 6R1008
  • Big A 30-351
  • Borg Warner RUE-1
  • E-tron BER, RU-12
  • Echlin ICR 24
  • Filko CH400
  • Holley 35-19
  • Kem FR57
  • Kmart CR1105
  • Niehoff AL125BCM, AL125B
  • P&D RU-13
  • Sorensen CE-3
  • Standard RU-12/RU-12T
  • Wells CR-105/CR1105
  • WVE 6R1008
40.5/5Dual, 1971 - mid 1975
3874767
  • Accel 150351
  • Airtex 6R1008
  • Autotron/Autotech C-901
  • Auto-Tune E-221
  • Big A 36-207
  • Daytona 9C10
  • Delco Remy C1102, 1972459
  • E-tron RU-12
  • Echlin ICR 24
  • Filko CH400
  • GC BR4
  • GP EL-401
  • Mighty 2-3005
  • Modern Mechanic CH456
  • Niehoff AL125BCM, AL125B, AL-402
  • P&D RU-13
  • Pace Setter RUE1Z
  • Palmer P12
  • Sears 28-83112
  • Sorensen CE-3
  • WVE 6R1008
  • Zenith 20-3005
41.25/5Dual, Late 1975 - 1979
4106140, 5206436
  • Airtex 6R1007
  • Autotron C-900
  • Big A 36-1
  • Carquest RUA1069
  • Cobra CH901
  • E-tron RU4
  • Filko CH401, CH401C
  • GC BR2
  • GP EL-401
  • Niehoff AL125C
  • Palmer P6
  • Sorensen CE-21
  • Standard RU-11/RU-11T
  • Wells CR-107/CR-1107
  • WVE 6R1007
21.25Single, 1979 - 1989
No metal strap.
Some listings show 5206436 as 1.0 ohm. Others show it as 0.7 ohm. Actual measured value is 1.2 ohms.
Manufacturers changed values and re-used some numbers. The table specifies the original ratings.
If changing the Chrysler electronic ignition to an MSD ignition controller system, the triggering for the tachometer is different. MSD is essentially a multi-spark ignition (at lower RPM) capacitive discharge system. It applies a higher voltage discharge to the coil. If a tachometer is connects to the coil negative terminal in this case it can be damaged from the higher voltage seen. MSD controllers provide a separate tachometer trigger that mimics the original style coil trigger signal.
For more information about the Chrysler electronic ignition system, including coils and ballast resistors, see the following:
8140C Super Stock
8140C = Chrome
Part NumberPrimary
Resistance
Secondary
Resistance
Notes
Chrysler
Number
2095501,
2196316,
2275590,
4106140
  • AC Delco C1101
  • BWD RU19
  • Carquest RUA1036
  • E-tron RU10
  • E-tron RU11
  • Echlin ICR 12
  • Filko AR-17
  • GP GCR7
  • Kem FR56, FR56X
  • Niehoff AL125A
  • Prestolite 32-20
3656199
  • Accel 150351
  • Airtex 6R1008
  • Big A 30-351
  • Borg Warner RUE-1
  • E-tron BER, RU-12
  • Echlin ICR 24
  • Filko CH400
  • Holley 35-19
  • Kem FR57
  • Kmart CR1105
  • P&D RU-13
  • Sorensen CE-3
  • WVE 6R1008
3874767
  • Accel 150351
  • Airtex 6R1008
  • Auto-Tune E-221
  • Big A 36-207
  • Daytona 9C10
  • E-tron RU-12
  • Echlin ICR 24
  • Filko CH400
  • GC BR4
  • GP EL-401
  • Mighty 2-3005
  • P&D RU-13
  • Pace Setter RUE1Z
  • Palmer P12
  • Sears 28-83112
  • Sorensen CE-3
  • WVE 6R1008
  • Zenith 20-3005
4106140, 5206436
  • Airtex 6R1007
  • Autotron C-900
  • Big A 36-1
  • Carquest RUA1069
  • Cobra CH901
  • E-tron RU4
  • GC BR2
  • GP EL-401
  • Niehoff AL125C
  • Palmer P6
  • Sorensen CE-21
  • WVE 6R1007
No metal strap.
Man you know your stuff. I appreciate the info.
