70-71 E-body Convertible Manual Top Hold Down INFO NEEDED
Dana67Dart
Northern, Colorado
Hi all,
I am developing a replacement plastic head for the 70-71 E body convertibles with manual top.
I am supplying screws and nuts to secure the plastic to the OEM spring metal. (A buyer could obtain rivets and use those if they want the most OEM look but they will not be supplied. The recessed hole in the plastic for the rivet / screw head is the same ID as the OEM part) I need to be sure my screws are the correct size so no drilling is needed to the OEM spring metal.
I need to determine the hole size in the ends of the spring metal the OEM plastic is riveted thru.
These are prototype mockups (Any dimensions that look off in the photos is just photographic anomalies)
I wish you were planning to fabricate the metal strap and make the whole assembly. With rivets. I would be interested in a couple sets of those.
if you have an OEM assembly now, can you not sacrifice it and drill out the rivets and measure the holes in the strap?
but if you were fabricating your own assembly, you would likely choose the standard diameter matching the rivet.
I'm working up a price for the spring metal and the plastic latch, rivets paint etc. Now for the tough part how much would you be willing to pay for a set of 2 pieces? This does not include the lower V shaped part that bolts to the body.
The plastic would be white not yellowed like the OEM part. (My guess is the original part would have been more white then yellowed originally????) it could be painted????
So I got some rivets...
Top one is a screw still. My rivet driver is too fat to fit in the area to drive the rivet in. Ill try thinning the driver in the conflicting area or modify the latch a tad to allow the driver to fit in. I'll have to make a proper shaped anvil to backup the rivet so to not mar the face of the rivet.
I got a price for cutting spring steel and its pricy for the first articals
I made a small tweak to the design, unperceivable to the naked eye.
I will be able to crush the rivets now.
Spring steel straps ordered
Latches ordered
Rivets in hand
Setting tool in hand
Shaped backup for the rivet head in hand
Well I got the 1095 Spring steel parts the other day.... minor setback. they were cut from annealed material. The manufacture knew the usage and they made the recommendation. What part of SPRING did I not explain?
ARRRG
at least they are remaking them with tempered 1095 spring steel (ie Blue spring steel)!
I got a sample of a tempered material and the NYLON plastic heads came in. Put them together with rivets and success. I can bend the head back farther than needed to latch or unlatch and boing, sounds like a gitar string! It goes right back to original! Amazing what the right material can do!
I have the rest of the order on the way and will need to paint and do some post processing on the plastic head but Ill have them available in a couple weeks.
As best I can tell semi gloss black is the right color and sheen
So they did make a manual top Challenger. Looked at a 70 Challenger yesterday and thought they had just eliminated the hydraulics. Nice car. The dealership has been around for many years and doesn't have the best reputation. I'll be passing on this one. Didn't know any cars in that era came with manual tops other than Triumph, MG and the like. Still like to find a 70 Challenger RT 440 auto convertible.
well a couple weeks has turned into a few months. I need to find a way to post process the plastic to smooth it. I'm going to try a tumbler with fine grit but finances are tight right now.
