I have a 70 cuda N code 383 A/C car for sale. Red on black. It is a matching number car . The vin is on the block, the motor is out of the car . The motor is broke down in pieces. It is missing the fan , right side exhaust manifold, carb, and air cleaner. The heads are 1971 . the owner couldn't find the original heads. There are very small pieces of the built sheet in the driver seat. VERY SMALL. It is a auto on the column car. 8 1/4 rear. Still has the original rear drum that are painted red. Original transmission. All the int is there but the carpet is gone
It will need a lot of sheet metal work. The frame rails front and rear are GOOD, doors are GOOD, fenders are GOOD. driver one had a dent above the wheel. cowl upper and lower GOOD, engine compartment is GOOD. rockers are GOOD,
Rust around the windows front and rear. trunk area, trunk drop offs, front floor and the small area behind the driver seat.
If you can do the metal work . You'll have a GREAT car.
If interested sent me you number and I will call you. Please don't waste my time and your. THIS IS A RESTORATION PROJECT. 70 cudas are getting harder to find these days. I have about 35 pictures of the car.
$5800.00
Thank you Jay
$5800.00
Thank you Jay
