1970 Dodge Challenger 383 4 numbers matching JH23N
charger peter
ok this is a complete project that needs ground up restore. its a very rare model non r/t 383 magnum sleeper. its a true sublime green car, numbers matching 383 4 BB and trans, fender tag , posi rear end, dual exhaust, front disc brakes, bench seat car, rear defrost, RIM BLOW STEERING WHEEL, dual mirrors, black vinyl top, black interior. its one of 952 produced with this combo not including its a true lime green car. you can check out info per caaarguide.com VR JH23 1970DODGE CHALLENGER 2-dr hardtop a 383ci V8 4bbl 330hp production 952 .. I know what it is so i am firm on price. you can always build a clone, but when is the last time you have a numbers matching car. solid frame rails but will need some quarters and body work.. but complete 99 percent. motor runs and good. Oil pressure good but has been sitting since 1995. was painted blue back in 80's but still can see stock colors. perfect dash panel and black door panels are very good no chacking..so there is 3k in savings by it self. rare posi is another 1k...so price is firm..and no trades ...appropriate the offers of trades..but dont need any ...its rare so no hurry to part..again not many numbers matching 383 complete sublime cars out there...and its a loaded car..
just got the motor running. and the car moves back and forth. Perfect to load on a trailer... again numbers matching car. to deliver figure about 1500 to 2k...car is located in Oregon 97301
comes with a replacement driver fender, a 70 flat hood and 70 correct gauge cluster....still missing bench seat..but I do have 2 good core cuda seats.. $14750.00
DetMatt1 I noticed that you are getting your message count up. Does that look like a stock intake manifold and air cleaner ? A fender tag or build sheet would be mandatory to justify the price. Not very well maintained even if it was parked for 20 years.
I just noticed that this is your first post here. Welcome aboard. Do you have any other Mopars ? Pictures ?
DetMatt1
Metro Detroit
I've been here a long time Leo! Looks like an aluminum intake, headers and yes the air cleaner all look to have been done sometime long ago.
charger peter
I will post better pics and yes I agree it may be high..but then being what it is with all the options numbers matching etc. ...I don't think I am out of line.. Car needs to be taken back to what it is..I see for a 318 basic challenger around in my area they start around 6500 to 7500. And u still need to have to buy a dash pad and interior panels,, Which I see for around 3k for repops. Anyways just wanted to put out here..cool forum.... Thx
charger peter
just had it towed over to my friends home after replacing fluids and parts..fired up..good oil pressure, car moves back and forth and radiator holds fluids also. anyways car comes with lots of extra parts..it has solid bones.. will post fender tag soon.
challenger6pak
You may want to run the new fuel line under the distributer against the valve cover. If you get a fuel leak where it is you could have a fire. You want to come up behind the alternator, not through the bracket. Hooking up the vaccum advance will help also.
68427vette
at that price I'm looking for a true R/T.. if you are going to build them build a true r/t. ALL these cars need the same things, trunk, floor work, outer 1/4s.. etc .
charger peter
its all good... its going to a good home..who wants an all numbers matching magnum car......not everyone wants an r/t. or they would have not build these cars... people like different cars for different reasons...
charger peter
caaarguide.com is one source that gives an idea of what something could be.. i have copied all the 383 options including the R/T's
1970 DODGE CHALLENGER 2-dr coupe 383ci V8 2bbl 290hp 1740 5800 17400 23200 34800 52200
JH23 1970 DODGE CHALLENGER 2-dr hardtop 383ci V8 2bbl 290hp 1770 5900 17700 23600 35400 53100
VR JH27 1970 DODGE CHALLENGER 2-dr convertible 383ci V8 2bbl 290hp 2745 9150 27450 36600 54900 82350
R JH29 1970 DODGE CHALLENGER SE 2-dr hardtop 383ci V8 2bbl 290hp 1860 6200 18600 24800 37200 55800
ER 1970 DODGE CHALLENGER 2-dr coupe a 383ci V8 4bbl 330hp 3 2040 6800 20400 27200 40800 61200
ER 1970 DODGE CHALLENGER 2-dr coupe 4-spd m 383ci V8 4bbl 330hp 3 2190 7300 21900 29200 43800 65700
VR JH23 1970 DODGE CHALLENGER 2-dr hardtop a 383ci V8 4bbl 330hp 952 2070 6900 20700 27600 41400 62100
VR JH23 1970 DODGE CHALLENGER 2-dr hardtop 4-spd m 383ci V8 4bbl 330hp 457 2220 7400 22200 29600 44400 66600
ER JH27 1970 DODGE CHALLENGER 2-dr convertible a 383ci V8 4bbl 330hp 84 3045 10150 30450 40600 60900 91350
ER JH27 1970 DODGE CHALLENGER 2-dr convertible 4-spd m 383ci V8 4bbl 330hp 31 3195 10650 31950 42600 63900 95850
VR JH29 1970 DODGE CHALLENGER SE 2-dr hardtop a 383ci V8 4bbl 330hp 644 2160 7200 21600 28800 43200 64800
ER JH29 1970 DODGE CHALLENGER SE 2-dr hardtop 4-spd m 383ci V8 4bbl 330hp 158 2310 7700 23100 30800 46200 69300
S 2 4 6 8 10 1970
R JS23 1970 DODGE CHALLENGER R/T 2-dr hardtop a 383ci V8 4bbl 335hp 6014 2220 7400 22200 29600 44400 66600
VR JS23 1970 DODGE CHALLENGER R/T 2-dr hardtop 4-spd m 383ci V8 4bbl 335hp 2590 2370 7900 23700 31600 47400 71100
VR JS27 1970 DODGE CHALLENGER R/T 2-dr convertible a 383ci V8 4bbl 335hp 576 3195 10650 31950 42600 63900 95850
ER JS27 1970 DODGE CHALLENGER R/T 2-dr convertible 4-spd m 383ci V8 4bbl 335hp 149 3345 11150 33450 44600 66900 100350
VR JS29 1970 DODGE CHALLENGER R/T SE 2-dr hardtop a 383ci V8 4bbl 335hp 2076 2310 7700 23100 30800 46200 69300
VR JS29 1970 DODGE CHALLENGER R/T SE 2-dr hardtop 4-spd m 383ci V8 4bbl 335hp 400 2460 8200 24600 32800 49200 73800
challenger6pak
Your guide is not in the real world. A 383 auto RT that is pretty nice goes for 25,000 - 30,000 in the real world, not 31,000 to 47,000.
charger peter
its like looking at NADA... ot 1133 - 1970 DODGE CHALLENGER T/A
$59,400.00* No Reserve Scottsdale 2016
Documented with the original Broadcast Sheet and Galen Govier Registry. Matching-numbers 340 Six Pack and automatic transmission. Outstanding ground-up restoration in 2015. Refinished in original Banana Yellow.
More Details
1970 DODGE CHALLENGER CUSTOM HARDTOP
Lot 1274 - 1970 DODGE CHALLENGER CUSTOM HARDTOP
$132,000.00* No Reserve Scottsdale 2016
"Coolest '70 Challenger Ever" by Popular Hot Rodding Magazine, selected as a top five finalist for the 2010 Street Machine of The Year. Over-the-top complete custom one-off build by The Roadster Shop. 528ci HEMI pushing 700hp; 5-speed manual transmission.
More Details
1970 DODGE CHALLENGER R/T CONVERTIBLE
Lot 1309 - 1970 DODGE CHALLENGER R/T CONVERTIBLE
$159,500.00* No Reserve Scottsdale 2016
One of 61 with a 440 Six-Pack, 4-speed and finished in rare Go Mango. Original-equipment, concours restoration, matching number body and engine, Broadcast Sheet, fender tag, rare SE trim, magazine featured and Galen Govier Trim Tag decode.
More Details
1970 DODGE CHALLENGER R/T 440 SIX-PACK
Lot 1424 - 1970 DODGE CHALLENGER R/T 440 SIX-PACK
$143,000.00* No Reserve Scottsdale 2016
Real "Mr. Norms" 440 Six-Pack, 4-speed R/T, Super Track Pak, rim blow steering wheel, matching-numbers, concours restoration, extensive documentation, Broadcast Sheet, Window Sticker, dealer invoice, sales contract.
More Details
Lot 418.1 - 1970 DODGE CHALLENGER R/T
$66,000.00* No Reserve Las Vegas 2015
This restored 1970 Dodge Challenger R/T has been upgraded to a 426 HEMI engine and 4-speed standard pistol-grip transmission. It has been customized with chrome wheels and amazing paint.
More Details
gdrill
Just North of Montana
Welcome to FEBO. You will find it is not necessary to upsell your car here. Most here know what these cars need to be restored and true value of such. Also the Scottsdale thing doesn't play a factor on a car that needs a total restoration. It appears that this car was in a very humid area, going by the rust inside the speedometer, the various surface rust and also on the valve covers. Do you have good pics of the frame rails near the back where they all rust out? Maybe closeups of the inner fenders at the hood hinge area too. That is hard to see with the rag hanging over it. I am suggesting that a lot more good pictures would help as you are asking a pretty fair dollar for the car. What is visible isn't really showing enough to make a good assessment of the car.
jimynick
Is it just me, or does anyone else think this car may have gone for a swim- in salt water? There's just too much rust in the damndest places- like the ash tray and rad cap. Caveat emptor laddies! Just my 2 cents worth.
challenger6pak
Broken windshield doesn't help much. The dash frame appears to be from a standard transmission car.
Rdwsp
Maple city mi
We all know how much this car cost to restore and we all know how much these cars are worth when restored it and went swimming in salt water for sure
