340 rear main seal
Kansan
Arkansas
Good Morning! The rear main seal has a so-so leak on my '73 'Cuda. I recall many years ago I would pull the oil pan on an engine (not necessarily a 340) and change the seal. I this a feasible fix on the 340. In time, I will rebuild the engine, but the time isn't right currently.
Thanks,
Kansan
Check & Make sure the oil sender is not leaking beside the dist First , this bit me in the past .
Good Point, Chryco Pycho....
Any pointers other than the oil sender. Back in the day, they used a rope seal and used a little cork screw device to remove the seal. It it still the same?
Kansan
Kansan
Lisle tools sold it. It was called Sneaky Pete.
Kansan
check out the articles here and on FABO on the same topic;
340 Rear main seal
