jackn440
hi, i have a 1970 challenger with a 383. it is not the original engine, and i have had it in the car for almost a year. it ran strong, but was getting some blow by and loss of compression, so i yanked it out and did a re-ring. while i was at it, i added a slightly larger cam, new lifters, new timing set, new h.v. oil pump. i got it fired up for the first time today, dialed in the timing, ran it at 2000 rpm for 15 minutes or so, good oil pressure, 10 degrees btdc, etc. the engine fires right up and runs fine until it reaches operating temp. as soon as it's good and warm, it dies instantly as if the key were shut off. i have good fuel pressure to the carb, the filter is full of fuel all the time. at first i thought that the coil (msd blaster 2) might have been getting too hot (let's face it, right on top of the intake is not the best place for it), so i moved it over to the inner fender well. same deal. runs fine for a while, then just suddenly stalls and has trouble starting again. after the engine stalled, i checked for spark and still had plenty. if anyone has any ideas, please let me know. (keep in mind, the car ran just fine before i pulled the engine and did not change the carb settings.)
