4 way flasher and turn signal flasher the same 73 cuda
rocketboy
found turn signal flasher above cig lighter. cant find 4 way flasher. turn signals work fine. no 4 way flasher if you turn on left or right signal with 4 way switch on they work.
If my memory is correct, there should be another located above the brake pedal. They are the same.
tman
Seattle
If you are able to, Turn on your 4 way flasher and listen for it. And correct, its near the brake pedal.
rocketboy
Ok i cant here it but i looked and cant find it yet . whats funny you turn 4 way on and turn signal on then 4 ways work
rocketboy
Hey guys i found it up in brake peddle area it was a square flasher replaced with new round 4 ways work great . thanks
