70 Barracuda Rear Bench Seat Mounting Bracket Kit
SFEbody
Los Angeles CA.
Can anyone tell me or show me photos with measurements for the bottom rear seat bracket locations?? I just realized after paint of course that my new AMD floorpans do not have them. I am referring to the two brackets that weld to the floor and the bottom rear seat frame hooks into it.
as a follow up are there any to be had aftermarket or nos around?
(Disregard the black paint mess from treating the insides of the pillars and frame. The 360 degree paint nozzles make a mess!) These photos are of a '70 'cuda. It looks like the brackets are on 26" centers, and are positioned on a recess adjacent to where the rear frame rails are spot welded on the inside of the rear floor pan. See photos, and let me know if you need anything in addition.
Hey WD, thanks much but obviously I described it wrong, I need the parts that are on the floor pan that the bottom of the back seat hooks into. The photos you sent are very helpful but are the upper back seat mounting tabs. If it is not to much trouble can you send the same info on those? Again, much appreciated.
I'll take a look tomorrow and send the info with pics.
Following. I need 1 lower hook if anyone has one...? I don't believe they repo the lower hook yet, but correct me if i'm wrong...?
Looks like the hooks are on 28 3/8" centers from one another. I believe as long as you use this centering, you can use the raised ridge stamped into the lower seat floor panel for alignment. See photos, and let me know if you need anything in addition.
