70 Challenger floor question
VRSCD
VA beach
Hi All
here i just gat 70 Challenger that will need the trunk pan and floor to the front og the passenger footwell , i have found on 2 sides the howl assy with the frame rails , my question is is there only one that makes it that way i was looking on AMD and i could not find it with the frame rails intact like a assy
Kind regards
Bo
i think he is talking about ether the trunk floor with frame rails attached or the floor, trunk and rear rails attached, but if i remember right that was for a first gen camaro. and it might have been dynacorn.
I hope that you realize that you will probably have to remove the rear quarter panels to install this assembly. Also you should find out from the seller who the part maker is. There is a big difference in quality between them.
IMG_3130.jpgYes this a big pice to install the problem on this car is was tubed back in the days so there is no rear floor in it but it has the part of the frame rails so it will be good for the install regarding references and measurements , i was just wondering if there were maybe more than one that makes this
Well I see 3 brands on their homepage, Goodmark, Sherman and Dynacorn. My guess is that's Dynacorn and that nobody else is Selling a part like that. I would say it would be your best bet for putting your car back to oem. Your other option is to buy The parts seperatly and use the factory chassis dimension chart to put it back together.
Hi All
found out this Dynacorn made does any one now how Dynacorn versus AMD for body parts need to buy some more parts like one front fender and little bits and piece
Kind regards
Bo
I've never heard any comments good or bad about Dynacorn so I can't say but I have used AMD and for the most part was happy with their parts.
