Flathead31coupe
There is a flat spring that goes on one side of the rear parking brake strut. Lever, it has a little piece, that is on one end of the Spring. How does to be installed?
[/url]There is a flat spring that goes on one side of the rear parking brake strut. Lever, it has a little piece, that is on one end of the Spring. How does to be installed?
Thank you ... Does it show the position of the parking brake strut lever, one end of the strut lever is slightly bent upwards or down depending on how you position itThe following image, from the factory service manual, shows the proper position of the anti rattle spring and tab:
[/url]Ok thanksMine are 11", must be different, the strut is contoured and can only go 1 way.
https://postimg.cc/hQDqvqWx][/url]
The larger brakes with the strut with the angled lip install with the lip facing upward. It's mostly hidden in the following image from my car, but you can see it at the edge of the axle flange.Thank you ... Does it show the position of the parking brake strut lever, one end of the strut lever is slightly bent upwards or down depending on how you position it
