8 3/4 b/e body swap
mopar397
ohio
I was talking to a guy today and he said you can take a b-body rear end and buy an conversion kit for it so it will work for an dodge challenger? Is this true?
Dixiedodge7369
The B and E body's have different track widths so there's no conversion kit. you can cut Down the axles and weld on new ends to get the proper length, or if your too short u have to completely remove the tubes and get new ones welded in then weld the ends on.
the 68-70 B body diff is a bolt in with the offset mount kit
Doctor Diff has the mount kit
rumrunner70
Hi I own a 70 challenger with a B body Dana in it , It is not that hard to do, Not sure who sells the offset purges, If I recall the B body is two inchs narrower then the E body.
