A727 3 speed transmission: Slight Vibration in Park and when driving
moparnut74
Hello. I get a vibration at certain RPM while the vehicle is in park through the floor of my 74 Barracuda. Feels like it could be something in the torque converter or transmission ?? It will go away at higher speeds & different RPM ranges ?? Please help. Thanks !!
AUSTA
PERTH WA
Has it always been there or did it happen suddenly.
I was thinking the same thing, Leo. Also check the engine and transmission mounts.
crash520
Ipswich, Australia
I have just been through this with my cuda, the vibration was at its peak around 1800-2000 rpm in park/neutral and whilst driving. turned out to be the alternator. So, first things first, drop the drive belts off and start the engine to see if its still there, if not, its either the Alternator, water pump/fan or Power steering. if it is check your flex plate etc as per the guys above and go from there.
