Accessory feed connectors with tan wires from fuse box
unclejesse
Nebraska
Anyone have a list of what accessories could be going into these 3 port connectors? Understand that all models wouldn't have had all options. The wiring diagrams always end at those. Then show up at random other spots.
As indicated the 3-way female bullet taps are for optional accessories not present on all vehicles. Color coded, yellow on a tan wire is from a fuse in the fuse box on the accessory bus, options vary, but if A/C equipped, the A/C dash harness connects there to provide power to the compressor clutch. Other taps are, Red for unswitched fused power, orange for the dash illumination circuit and on some other platforms, a black 3-way on yellow wires tapping into the door pin switch circuit.
If you are unwilling or unable to read a schematic provided by the FSM, I'm cool with that. But the information you seek is atypical, so someone may have to research it to answer your question. Or we can guide your journey so you can research it, yourself.
Google (or most other) AI is not an ideal fit to provide reliable data on this topic. But the old-timers, here, can still deliver and get you the help you need. Just let us know your skillset and what level of specificity you may want.
My two yellow 3-way female accessory connections come off the fuse box & do not connect to anything.
I'll find something to stick in one of them.
There often is nothing plugged into it but it would be a feature that would be on with the key either turned forward to run or backward to acc position such as separate feed for a radio
