SpiderHelix
Anyone done this? I am looking for ideas where to mount the mega fuses and help figuring out the starter circuit.
I like the terminal idea which is basically what I have in the MegaFuse holder. ThxI have wired everything in the past .
The way I do battery in trunk is to use welding cable , indestructable & flexable . I run the + to the starter & feed power out from there or use a terminal after the starter & run the - to the trans not the frame then run a jumper to the body from the engine or trans .
The rest can be wired as normal with the fuses etc at the front or other desired location
