Big Block Cooling Help/Opinions
co5j
Coastal NC
As always, backstory on Welcome Wagon, generational 70 Challenger has made it to our residence with some long standing cooling issues never addressed by my wifes dad (Diddy, 91yo). Apparently most of the gauges are useless, so ill be purchasing an aftermarket for the short term, drove it about 40 miles with outside temps in the upper 90s to get it to our house and the needle never moved from "C". Mechanical gauge best or is electric fine? Diddy has removed the thermostat (he's an old school drag racer), so I'll be replacing that. Currently a stock 26" radiator, not sure about cores, with shroud and stock clutch fan. What all do I need to be looking to change to do this justice? 440 6bbl setup with mild cam/mods, no AC, stock exhaust manifolds.
pschlosser
Santa Rosa, California
The cooling systems on these cars were pretty good. The 26-inch radiator providing the best cooling. The fan shroud and clutch fan offering even more cooling points.
Even during a heat wave, when the cooling system is working normally, the engines do not overheat unless you're hot-rodding significantly. And with moderate driving, no overheating at all.
So where to start looking for your overheating problem?
Core flow - check that radiator core and confirm its ability to cool, could be plugged cores.
Coolant flow - check that water pump
Timing - engine timing can contribute to engine heat, so make sure it's not too far advanced
Measure - measuring coolant temps can be as easy as a meat thermometer stuck into the filler neck of the radiator.
Clutch fan - check the clutch on the fan when warm and check airflow through radiator.
Engine flush - a longer engine flush, and even one where a freeze plug is removed to flush out casting sand, can improve cooling a great deal.
Deathproofcuda
Seattle, WA
I agree that stock 26" radiator with shroud and clutch fan should be adequate for your needs.
First thing to do is to actually confirm whether or not you have a cooling problem. If you don't have one already, buy a cheap IR thermometer, then take the car for a drive. After it warms up, pop the hood and take some temp readings on the radiator body and water pump housing.
co5j
Coastal NC
I think most of my assumptions that it could be cooled better, are lack of thermostat, gauge that was no help at all, and the fact that about 20 miles down the road it cut off every time i had to stop at a light/traffic without shifting to neutral and idling up. Just seemed hot.
A good flushing won't hurt anything, a new thermostat and getting a temporary temperature gauge plumped into the water pump housing will tell the tale if it's getting too hot. Right now, it definitely sounds like it is. You're on the right track!
Deathproofcuda
Seattle, WA
Cutting off seems more like a carb or timing issue than overheating. As @pschlosser said, timing will impact engine temps, although I'd say its more likely to run hot if too retarded. Factory timing specs were intentionally retarded to raise exhaust temps for cleaner emissions during that time. Car running too lean will also contribute to overheating.
MoparCarGuy
The correct thermostat ensures the coolant has time to shed its heat while in the radiator. This "dwell" time is critical.
Having a lower temp thermostat allows the coolant to circulate constantly with minimal or zero dwell time which hurts cooling system performance.
A quality 195°F thermostat (hi-flow) will aid coling for those in the southern US.
co5j
Coastal NC
Most of the info i have shows a 195° stat, Xcudame suggests 180. Opinions? I bought a 195 but hey, $10. Im not even putting it in until i change the plugs n a new set of wires this weekend, old ones are burned all to **** laying across manifolds. 🙄
co5j
Coastal NC
Having a lower temp thermostat allows the coolant to circulate constantly with minimal or zero dwell time.
View attachment 142043 View attachment 142044
Thank you, great info!!!
I'd go with anything thermostat above 180°F. I have no issues with a 195°F. Some people like to run 160°F and I'm my opinion, that's to low.
Cratos
Sunny Florida
Powerflush engine and rad helped me and runs a lot cooler now
if it is shutting down, most likely vaper locking due to the crampy ethanol fuel. I had the same thing here in FL when i got mine on the road. I ended up switching to a return fuel set-up and .250 insulators under all 3 carbs. also switch to non-ethanol fuel.
540HemiCuda
West City Il
Seems to be a lot of information provided here that flies in the face of my experience with over temp issues.
First, you have provided very little in the way of information to help. So, this will be general. One rule of thumb that is a good way to start is by asking WHEN it gets hot. Over temp at slow vehicle speeds generally indicates an air flow problem, while an over temp at road speed generally indicates a water flow problem.
Second, the 190* recommendation was part of the emissions protocols. It had nothing to do with performance nor longevity. Without getting into a side discussion, the slant 6 recommendation may be the exception due to it's design. After about 180*, wear is near negligible so there is no reason for higher temps. An old racer's adage that was accurate was; cold engine, hot oil. The ONLY down side to 160* engine tempo in a street car is accelerated wear. Otherwise colder is better. Pay attention to what is going on with the Hellcats to see what I mean.
Third, 'dwell time' in the radiator is a non issue. The only issue would be that there is not enough air flow to accommodate the water flow. If there is enough air flow, removing the thermostat will NOT raise the engine's temperature.
And we have fought over temp issues on these big engines as soon as the cars aged just a bit and things were no longer optimum.
There have been a few good suggestions already. Here are my thoughts without more particulars:
-Block off the heat cross-over in the intake if it isn't already. Today's fuel has a much lower boiling point than fuel had when these engines were designed. Heating up the intake's floor with exhaust gases is very detrimental to your engine's operation.
-Verify your timing as already suggested. And your engine LOVES a lot of timing at idle and having the timing in as fast as possible. I have mine all in by 2,000. But be cautious not to put it into detonation in high gear. If you chase this, it's best to get some experienced help. There are valid reasons why the factory installed a more conservative curve than the engine really wanted.
-If you have access to a temp gun, scan the radiator for hotter and cooler areas that would indicate blockages. Also check for the temp drop between the inlet and outlet. I don't remember what the recommended target is, but not enough temp drop indicates an undersized radiator or lack of air flow.
-180* thermostat is your best compromise on a street car. There are no dependable hi-flow thermostats any more that I know of. If someone knows of good dependable ones, let us know. The Mr Gasket ones are JUNK. Get a good quality thermostat and drill a few extra holes for additional flow. Contrary to previous opinions, I ALWAYS chase over temp issues without a thermostat. If it won't cool without a thermostat, is sure isn't going to get better with one.
-The bypass hole in the water pump housing is way too large. We used to use motor home thermostats that would block the bypass opening when it opened, but I haven't seen one of those thermostats in decades. What you can do is to remove the thermostat and when you look into the housing you will see the bypass hole. All it does it allow heated water to get to the thermostat when it's closed, so it knows when to open. After that, all it does is to continue to allow heated water right back into the engine, bypassing the radiator. Drill and tap the bypass for a brass plug, which you drill with as small a hole as will still allow the thermostat to open properly. Usually takes a few tries after starting with a tiny hole.
-Replace the fan clutch. They do loosen a bit over time. I replace mine every couple of years.
-Use as big a fan as possible. I actually cut down an aluminum truck fan to fit in my shroud. Moves a TON of air. Mancini and others have fan kits. At least compare their pictures to your fan to make sure yours is similar. Look at the number of blades, their size AND angle.
-A proper shroud is a MUST. And the fan should be positioned properly in the shroud. Pics of original cars will show you better than my description here.
-You can change the water pump drive ratio by changing pulleys. May be a bit of a stretch to do that, but just make sure that the pump and fan is not being driven too slowly for your application.
That is not everything, but is a start. Keep us informed on what you find out as you chase this. These big engines can be difficult to keep cool. Everything must be fairly correct or these engines will not cool properly.
Ricks72Chlgr440
Sisterdale, Texas
I've been using the high flow thermostats from Stewart Components in both my 408 & 512 stroker engines with good success. I also use the Flowkooler high flow pumps on both as well.
540HemiCuda
West City Il
Those Stewarts look EXACTLY like the Mr Gasket hi flows. I hope these are better.
There used to be a video around where someone tested as many different big block water pumps as he could find. The results were surprising. Many cavitated way earlier than one would have thought even if they had good flow at slower engine speeds. If I remember correctly, one of the most important points was how close the vanes were to the housing.
But that was many years ago.
co5j
Coastal NC
Minor update, I at least have a working "idiot" gauge (C - H) in the dash, although I still plan an aftermarket with actual temps until I get to replacing the instrument panel with updated gauges. Accomplished by installing a thermostat and new temp sending unit. The radiator is claimed by FIL to be a 4-core stock 26" replacement that he sent off to be cleaned and fins straightened, and it does have air flow through it. So heres where I'm at, he has a 5-blade fan w/clutch installed, everything I see shows a 7-blade fan, was going to get one from Mancini, my question is concerning the clutch, I want to replace it with the fan, thermal or non? I have a Chiltons from when I owned a '71 back in the day that states the thermals were used in vehicles w/AC, which this vehicle unfortunately does NOT have. Opinions?
