FOR SALE Carlisle 2023 Parts Spaces IA1 IA2
Cudaize
Jamison Pa
Below are some of the parts I will be bringing to Carlisle spaces IA1 and IA2
71 Cuda Reproduction Parking Light Lens pair, New 150.00
Outside Door handles Repro Cuda, New 100.00
Rallye wheel Center big bolt NOS $100.00
3501154 NOS Antenna cable 72-74 B-body, same connectors as E-body but 9” longer 200.00
71 up NOS slapstick console plate assembly, some fine pitting, no original box, 500.00
Road wheel (Magnum) reproduction (OER) center dome set with backers and hardware 100.00
Challenger convertible short die cast have several pairs all original used 50-100 depending on condition
Convertible windshield pillar interior plastics in burnt orange no cracks have decent color and don’t seem to be chalking 300.00 pair
Convertible interior windshield header and corner pieces black, very nice used condition 1500.00
Overhead console molded console only, long chrome strips no dome light or indicator lens 50.00
6 way seat frame, only looks to be surface rust, missing some springs and no knobs 700.00
6 way seat under floor bracket, long only 100.00 each, (2) available
Challenger standard painted gas cap from 71 30.00
Space saver tire on Ford rim, F78-14, replaces 7.75-14, non-DOT early tire 750.00 each (2) available
Chrysler Kelsey Hayes 14 x 5.5 wheels (6) hole, 70 date, need repair by lug holes 100.00 each (2) available
Space saver F78-14, newer BF Goodrich with “Temporary Use Only” one side on GM rims 200.00 each (2) available
Space saver inflator, original shorter than most I have seen has ECS sleeve 300.00
Space saver inflator, repro from solid stainless, I think, bottom, top and valve very close looking to original, lower quality repro label 150.00
Rim blow, used, no cracks, switch worked last I tested it, woodgrain worn, no center 500.00
New replacement brake drums 11X3 front no hub, 11X2-1/2 rear had 20+ years, I think US made but not 100% sure $200.00 pair
Cuda arm rests reproduction black pair 60.00
Alternator made from all NOS parts to look like 3438172 but no stampings, 400.00 each (2) available
Rear light harness 70 and 71 Cuda convertible by Evans, never used $200.00
Rear light harness 71 Cuda convertible by M&H, never used 200.00
Headlight harness 71 Cuda by Evans, never used 200.00
Kick panel insulation E-body REM 20.00
Door weatherstrip with seals installed Metro 60.00
Under dash pad REM 20.00
3670672 72 up ignition and door lock set NOS $150
Hood latch 71 Cuda black zinc plated, not taken apart dated 1691 150.00
4668 Holley dated 1661 for 71 383 auto, old rebuild but not used assume need to go through $350.00
6253 Holley dated 1140 needs rebuild 150
4369 holley, froze 40.00
71 small block PCV valve NOS SSC stamp on bottom 75.00 each
70-71 big block 3 rib PCV valve NOS 75.00 each
71 Cuda foam back trunk mat reproduction, never used 100.00
3579219 distributor collar, spacers and pin package for some dual point including T/A AAR 10.00 (3) available
