Cooling fan alignment
doubleadad
Jackson Michigan
I have a 1970 383HP Cuda. The 18.5 inch fan will not fit in the shroud.. It appears the engine is setting to high in the K member. My question, are there multiple motor mounts? The engine bolted right in, but the mounts may have come off a 440. Is there a diference?
69hemibeep
How close to fitting is it? Is the transmission hanging to low?
doubleadad
Jackson Michigan
Fan is roughly an inch to high. Trans appears to be all correct. I keep returning to motor mounts but those to look correct..
fasjac
Arkansas
If all the parts are original. I’d probably visit the body demission section. Check the measurements and verify the radiator core, lower cross member are in specs. I’ve seen motor mounts that are a bit to thick as well too. Should be easy to find the issue. Post some pics if you can.
