Cowl Stamped Numbers Question - Straight line?
440WB
Michigan
Question - Cowl Stamped Numbers - are they supposed to be in a Straight line?
looking at the numbers the 2nd digit from the last is below the others almost 1/8" -
at least a 1/16" ( it is noticeable )
fonts with placement and size looks correct -
sorry I did not get a picture of it - ( car is too far away to go back and get a picture - 2 3/4 hour drive each way )
440WB
Michigan
makes me wonder -
didn't they have a fixture to clamp and press with the numbers inset for a perfect stamp?
I have to say that this is more common than not. from what I have seen.
440WB
Michigan
So maybe the number insert in the block has moved inside ?
440WB
Michigan
From what I have seen in the industrial shops with die’s - molds Numbers / letters are usually fixed inside a fixture
pschlosser
Santa Rosa, California
From the tire-kicking stories at car shows: Yes, most (if not all) sheet metal numeric stamps (even those with changing numbers) were gang stamped using various types of jigs.
But on occasion, when a given assembly line tool or die is in disrepair, they had to keep the assembly line moving, so they made due with the broken one for the rest of the shift until it could be repaired or replaced.
Therefor, on occasion, some legit factory stamps may show misalignment along the baseline.
But not ****-eyed or (slightly) rotated numbers. Those containing digits not straight up and down with the others? Those were not done at the factory. Possibly the dealer, but from what I understand, not the factory.
440WB
Michigan
'But on occasion, when a given assembly line tool or die is in disrepair, they had to keep the assembly line moving, so they made due with the broken one for the rest of the shift until it could be repaired or replaced.' Quote
in the later 70's I had worked in a tool and die shop - we had punch press machines in operation to stamp production parts for the big 3 - I agree with the above how you say - sometimes the operator would just keep going even when they knew it was wrong -
sometimes they would have to wait on us to make the repair to get by -
until we could remake a new piece
