Has anyone else installed a Classic Performance Products power disk brake conversion kit? I got this kit through Year One and so far I'm having a rough time getting them to work right. The first thing I noticed from this kit is that the brake pedal doesn't seem to come out as far as I would think. For reference I assume that the brake pedal should be about even with the clutch pedal, but it is an 1" or 2 closer to the firewall. The real problem though is that the pedal moves a lot when actuating the brakes and seems very spongy. It will stop the car, but it's a little scary. The kit comes with everything you need to convert the front brakes from drum to disk. I installed it on a '70 Cuda. I bled the master cylinder before installing so that is in good shape. The only line that isn't new is the one between the connection near the firewall and the rear end connection. There are no leaks in the system...well it's not losing any brake fluid anyway and nothing is wet. The rear brakes are still drums and I have adjusted those out so they don't have to move hardly at all to touch the drum. I bled the brake system twice now. I have pumped so much fluid through there it is ridiculous. The first time I bled them with someone pumping the pedal while I operated the bleeder and the second time I sucked the fluid out of the bleeder with a pump. When pumping we got the back brakes bled good, but the fronts seem to always have small bubbles no matter what. We never ran the master cylinder out of brake fluid. Seems weird that we got the back brakes good but the fronts not so much. When I sucked the fluid out it was hard to tell if I was getting air out or if it was coming from around the bleeder. I tried to put thread tape around the bleeder, but that wasn't perfect either. The bleeders on the front calipers are at the top. Anyone have any similar experience with this kit and/or brakes in general?
