Dang hippy...
fungus
Greetings from Tennessee!
I'm actually not sure if this is the place I should be, but I need guidance at least on where to go.
I have an engine and transmission from an '84 Laser. 2.2 turbo, it's the class I turbo (mechanical wastegate). Talk about a beautiful piece of engineering.
I currently have a bunch of random fuel delivery parts, but not enough quite yet. Only things I'm missing are the throttle position sensor and the wiring harness. My buddy gave me all the other parts I need, which were all off of a '88+ system. Seems that those use a single ECU instead of the traditional split ECU.
I'm going to see what I can find at pull-a-part this weekend. Any advise is greatly appreciated.
D Dodge
La Porte, Indiana
I can't help you but some of the other members might be able to. You might want to check out the A body and B body forums that are listed at the top of the Home page. There's a lot of collective Mopar mechanical knowledge here. Good luck.
