Ebay - Air Gap for 340
if you have reason to deviate from factory setup and oem parts, many like the dual plane edelbrock.
I've never heard of this AirGap. Others may chime in, but if not, it seems like a crap shoot.
I have never used one of these , I have used the Eddy RPM , Eddys use a soft alum & have poor port alignment , not high Quality so possibly this is actually made from better material or at least equal , could be the casting is more accurate also .
If your heads have not been milled down this should not be hard to fit .
Probably worth the gamble for the price , IMO
I find it hilarious when these "air gap" intakes started popping up for various engines because Chrysler big blocks have had "air gap" intakes since day one in 1958!!
Glad I've kept my old LD340 (not an air gap) as it's probably a better intake than all these Chinese "air gaps". I'm betting they are all "dirty" castings meaning it would be hard to weld on one because all the impurities in the aluminium will migrate to the weld area and makes a porous/brittle mess (and I'm no welder!). Hopefully an aluminum welder will chime in!
I guess for $145 you could get one and install heli-coils in the four carburator threads and two more for the thermostat housing and it might be a usable intake that works as well as a factory iron 340 intake. I don't see heli-coils in the photos l, but with cheap ChiCom aluminium, I'd definitely install them!
Just searched eBay and the only two LD340 intakes are one for $540 that need welding and one for $698 that's been welded! I need to sell my 340 small block stuff and buy a 6.4l Hemi crate motor! Zowie!
Eddy, Edelbrock, I guess they are similar. Apparently I've been living under a rock because I've never heard that before.
Oh, and to the person who said their intake manifolds are made in China. According to their web site and what I've heard from "Eddy" employees they are made in San Jacinto CA where they have a foundry.
Ok I was wrong , not made in China but still not made with decent quality or materials
Most I have seen , heads & intakes etc have bad core shift . 1 customer bought a carb where the fuel bowl wall was not cast so the counterweight for the air door was sitting in fuel , it had a quality inspection sticker etc , no one would take responsibility , no exchange or refund + when porting the Alum is very soft .
Not a fan
The Chinese knockoffs on eBay look the part of an Edelbrock Performer RPM Air Gap 7576 intake manifold but do not expect the knockoffs to be milled correctly. Also, the knockoffs are milled to fit both Magnum and LA small blocks (vertical intake bolt holes AND angled intake bolt holes) so you have to install cheesy aluminum drive-in plugs (provided) in the holes that go unused. Also, some of these knockoffs are either missing the water pump bypass hose connection threaded hole or have made it straight vs angled. See photo, circled in green for the correct angled version on the real 7576.
And the knockoffs may or may not have your normal accessory locations for the coil bracket, return spring bracket, etc.
Plan on making all of that work on your own. More time wasted.
A friend recently installed one on his LA 360 engine. It leaked coolant at the coolant passages at each corner.
Poor installation? Incorrectly milled intake? Why take the chance?
For $150, plan on spending another $100 (less if you do the work yourself - $50?) for a workable intake?
Maybe I should buy one and see what all is needed to make it usable and decent?
