Electrical wiring harness
demon3406pk
Looking for a new wiring harness for a 73 Challenger Rallye. Former owner put a PAINLESS wiring kit.
I want to go back original.
Thanks in advance for help.
They are available from year One and Classic Industries, but I think they are made for them by another company; Im sure someone here knows who...
But there are valid reasons to upgrade the under hood wiring on these cars. It is usually recommended to bypass the ammeter and run a wire from the alternator directly to the battery, especially if upgrading the wimpy factory alternator. Also, you should probably replace the ancient ammeter with a volt gauge, they are also available. You should clean the terminals on the bulkhead connector and lube them with dielectric grease to prevent corrosion. I also recommend upgrading the headlight circuits with the relays and sockets from Daniel Stern Lighting. The factory headlight wiring is not adequate.. unless you are doing a full restoration and need an original appearance.
http://www.danielsternlighting.com/tech/relays/relays.html)
I got mine from Year One ,same as original. Just wait till they have 25 or 30 % off. I get emails from them all the time with a promo code. If you dont get them let us know and we can give you a code. Rick
