frame connectors
Cratos
Sunny Florida
need some photos please I am thinking of going with the mopar bolt on frame connectors ( I don't want to pull the interior ) can you still use your parking brake (is there room between the connecyor and the floor pan. for the cable)
I always made my own using 1" x 2" .125 wall rectangular tube , I put in a notch at the lowest point of the floor pan & weld it back togther , then weld next to the T bar hex in the front cross frame using a slightly larger plate to spread the load & blend into the front of the rear subframe , no reason to pull the interior that way & it costs about $20 in materials
