Fuel Mix/ idling issues...
cv70chall
South Florida
Hi everyone! Hope we've all recovered from our turkey comas. :)
I've noticed over the last couple of weeks that my exhaust smelled a bit rich. A few days ago, after filling the tank, the engine sputtered and died at the light- and it took a couple of minutes and attempts to start it before it cranked back up and seemed to run normally- until I slowed to pull up the driveway and it nearly sputtered out again.
Does not seem like an idle issue, so what could it be? The car runs good, idles nice. I ordered a new set of plugs (the existing plugs are a bit over 2 years old- but I've maybe put 500-600 miles on the care in that time, so not sure if it's the culprit, but they'll get replaced anyway.
Can a slightly loose spark plug cable cause this? I'm asking as I felt that two or three wires seemed a little "loose".
Thoughts, anyone?
Could have a gasket leak inside the carb or just need tuning correctly , or possibly you have more ethanol in the gas that you bought recently .
I would suggest tuning it .
Not sure why you are running such a small carb on a 440 , I typically use 700-750 on 340s
Agree with all. Read those plugs when you replace, they tell a story.
The carb was a knee-jerk mistake. Planning on a 700-750cfm in the Spring. Carb was tuned about 8 months ago.
bad wires will cause problems running lean you will get a missfire smells really bad cheak the color of the spark should be blue
