Hey,
I'm doing a complete re-wire of my '73 Challenger using one of 'Painless Performances' complete wiring harness kits and about 3/4 of it is complete. I've waited a while so I could ask I hole bunch of questions at once.
1. There is a small white plastic button which has two red wires coming out of it and is located under my key ignition in the steering column;
what is it for?
what is it supposed to be wired to?
2. Where is the oil temp sensor mounted on my 340ci engine?
There are 2 small lugs on the front passenger side of the engine, they are directly beside the heater hoses, is it one of them?
3. While taking apart the steering column I discovered the horn switch in my steering wheel wasn't wired to anything
4. The following is all related to the ignition control unit/orange box and its also where I get really lost!
a. When I go the car in January most of the wires on the ignition control unit where hanging loose, but the engine ran perfectly?
b. Would an after market distributor make the unit redundant?
c. If I need it, how should it be wired?
All and any input would be appreciated,
what is it for?
