Heater control cables
PECO
Just putting a"70 Challenger together and I have a question.
I've reinstalled the heater cables and they do not look right.
One cable is up against the the throttle cable which will cause it to wear thru' '
and the other cable just flops around loose.
This is a non A/C car.
There is about a 1/2 " space between the steering column yoke and the cowl.
To me it would make sense that that is where it should be fed thru'.
Please respond if you can confirm or have another option.
See if these pics help you.
