ignition on only wire
Cratos
Sunny Florida
I need an ignition only on wire to use as a trigger for gauges but not on in Acc mode cant seem to find one :(under the dash.
What about the power wire to the stock gauge cluster, going into the cluster voltage regulator.
Dark blue with a trace at the brake warning light is IGN1, switched power ignition run only. Can also get that at that circuit at the ignition switch Molex.
