Ignition Problems
Zyli
Tyrol , Austria
Hi at all
My 74` Barracuda 360cui with MSD 6200 Ignition Box and new MSD Blaster SS Coil don`t want start .
The Spark Plugs are without fire and at the Blaster SS Coil are no energie .
The wiring are all ok , also the Starter Relay .
I check something with the Multimeter but found nothing .
I will check now the Ignition switch but the Steering wheel lock is in the way .
How I get the Steering Wheel Lock out that i could check the Ignition Switch ?
For what are the 2 red cables in the right background ?
How I could check if the MSD Ignition Box are working ?
How I know that the Distributor Pickup are bad ?
On the Distributor be a new Distributor Cap and a new Rotor .
THX alot for help
AUSTA
PERTH WA
Hi at all
THX alot for help
the 2 red wires are for the key still in ignition warning buzzer if fitted.
What type of distributor (standard electronic , points or after market electronic with hall effect)are you using & what wires on the MSD are you feeding the pulse into
Ok the small red wire from the MSD has to connect to both the blue & brown wire at the ballast resister plug , if the brown wire is not connected you will not have power while cranking so it will not start so this is the first thing to look at .
If you need to get the lok plate off there is a small collar above the plate , arefully pry that up & below the collar is a roll pin tap that out & the lock plate will slide up the column allowing access below the plate .
Make sure the gap between the pick up & reluctor is .008 in the dist if you are using a stock electronic unit .
Let me know if that works .
