My 440 rebuild thread
Righty Tighty
Sahuarita, AZ
Well folks, don't do what I did. I bought my 74 Barracuda with a 440 six barrel last April, and hit sat for around 20 years without being run or turned over, according to the previous owner. I got it home, changed all the fluids, belts, hoses, plugs, etc., oiled the cylinders and turned it over by hand several times. What did not do, however, is prime the oil pump. It didn't even occur to me.
Previous owner told me the engine was a fresh build (20 years ago), and that it had maybe 500 miles on it. He said he was having trouble getting it tuned, got frustrated, and threw it into storage where it sat. I got it started and it ran ok, but the idle was extremely high once it warmed up, so I played with timing and fuel settings, and got it to mellow out.
There was always a problem that surfaced around 2800 RPM, and that was a stumble/pop/afterfire out of both exhausts. I tried many things from troubleshooting ignition and fuel, checking plugs, wires, nothing helped. Finally, I had a moment. Yesterday I had a valve cover off, and noticed the rockers were all just about at the same angle. Dammit. I'm pretty sure I know what that means. My cam is flat. Whether this happened because I didn't prime before starting or the previous owner didn't break it in properly, I don't know.
I need to pull the engine and confirm (also cut open the oil filter), but I'm quite certain that's what it is. So, I wanted to start a thread documenting my 440 rebuild for those interested, and because I know I'm going to have questions. I rebuilt my 318LA a couple years ago, and had immense help from the members over at FABO, so I'm pretty confident going into this.
The previous owner couldn't provide a build sheet for the engine, so I never knew what cam was in it, pistons, etc., so I'm excited to be able to tear this one down and build it how I want it, and now I'll KNOW what's in it.
Thanks for reading, and I hope you all will follow along.
70chall440
Western Washington
Its hard to say when/how the cam got wiped but in my experience if the engine was originally broken in without wiping out the cam then it should have been good. What oil did you put into it? Really doesn't matter now either way and rebuilding it isn't all that difficult.
Righty Tighty
Sahuarita, AZ
I used Lucas Hot Rod & Classic oil - high zinc at 2100ppm. I was thinking about how when I flattened the cam in the 318, the car barely ran. This engine has always run - albeit poorly. But as long as I keep the RPMs relatively low, it still runs.
But you're right, the rebuild won't be all that difficult. I think the most difficult part will be coming up with a plan, mostly cam choice and whether I want to keep the iron heads.
Righty Tighty
Sahuarita, AZ
Quick update. The cam is fine, I didn't realize that the lifters had bled down when I popped the valve covers off, and that's why the rockers were all the same angle. I still had the popping issue and #6 and 7 plugs were badly fouled (sooty). I learned that the exhaust retainers were rotators, I had gotten some advice to swap them out for standard non-rotating retainers.
So, yesterday I removed the heads and today I'll be taking them to the machine shop. I spoke with their head guy and he said it wouldn't be a problem at all to get new springs, even though we don't know the cam specs. I'll get new valves as well, and he's going to check for cracks and check the seats as well.
Righty Tighty
Sahuarita, AZ
I sent the heads off to the machine shop to have the valves and guides checked, also get the rotating retainers replaced for non-rotators. Turns out some of my springs were broken. The owner (whom I spoke with) said his cylinder head guy is out with covid, so he didn't know exactly which or how many springs failed. They're pretty backed up being down a guy, so I told him to take his time and that I wasn't in a rush.
In the meantime, I measured the cam for lift. Turns out this cam is smaller than the cam in my 318! Initially I measured against the hydraulic lifter and got .417/.417, which didn't seem right. I removed the lifter and measured straight against the cam lobe and got .441 intake and .458 exhaust. So I relayed those numbers to the shop so he can get me some springs. While I wait, I'll freshen up the electrical and install the aluminum radiator.
Righty Tighty
Sahuarita, AZ
I agree, aluminum heads are indeed in the plan, just not quite in the budget right now.
Trick Flows would be my first choice from what I've read, but when Stealth heads are almost 1/2 the cost, they are a tempting option. I haven't been able to drive this car farther than to the store and back since I bought it, so it would be great if I could just get it running reliably while I plan the rebuild.
