Need Help with rear brake light harness
gran coupe john
Ohio
I got no dash lights, or brake lights. Although I have key light, and light by headlight switch when I open door. I don't know if this module has anything to do with the brake, and dash lights?
What said Chryco Psycho is true. I question this. If the headlight are working then there is enough power for everything to function properly. Low battery or terminals bad connection + and - . Bulkhead connection good and both under column connections good.
When motor is not running power is supplied by battery. Travels from battery to bulkhead connector 16 to red wire A 12R to amp meter. Follow the blue and yellow dots. Then to 12Bk to splice one. This is where it feeds all the loads or circuits. The headlights are feed from splice 1 through the Black wire white tracer. Q3 12R One red wire from splice one feed the battery side of the fuse box. J1 12R The other red wire feeds the ignition sw. Follow yellow dots. The Black wire R6 12BK Blue dots comes from the alternator. It supplies power for the load and charging the battery. BE AWARE! When the key is on there is power the alt terminal. This a summery of the power supply. Don't forget about the ground.
With a test light. Check the turn signal sw connector for power while plugged in. Go through the functions and see what you get. The horn connector is a ground for the horn relay that you pulled out.
We will be starting it tomorrow. Hasn't ran since 97. Wanted to get some of the wiring fixed before it gets finished painted.
Thanks, for the trouble shooting, will try this tomorrow. Will keep you posted
By chance I was having 4 way issues. Sometimes they don't work and you go to check it, it works. 🤔 :BangHead: :realcrazy:. The 4 way sw gets power from the pink wire from the flash, that is also power for the brake light. I pushed on the pink wire terminal and it works for now. The white wire from the brake sw completes the brake light circuit through the sw. I marked the pink wire 4 white wire R and the green wire L. The fix is to get a new turn signal sw.
Never had time to mess, with the mess on the wiring. Worked on starting the car. Had no luck with that either.
Test at the resistor. Unplug the brown and blue wires. Run wire should be hot when ing in run position. Start wire will be hot when holding in start positions.
Brown wire is the start wire. It only has power when in the start position. It applies full voltage to the coil when starting.
