No Spark and Distributor Pickup
rdstudio
Poland
Hello
I got 1970 Cuda AAR with 340. Car was running great for few years. After winter time I wanted to start a car, but no luck.
Cranking but no spark.
Checked all things also coil, ignition box, all good. When grounding coil pickup it make spark.
So next step was to check distributor pickup. I made ohm measures - have strange values like 10 ohm (should be 250-500), also check if when cranking will it produce some AC V (like 0.2-0.3v) but no.
Air gap is a little bit tight - but it will not touch reluctor.
So what should be my next step? To replace pickup? Should I also buy reluctor? I have read that it should be part LX-102 and LX-104.
Photos :
Nothing has really changed ecept corrosion. Cap,rotor and reloctor, check it.
Just to be sure check the following.
When the key held in the start position (START) you should have battery voltage at the Brown wire at the coil. If not it is the wiring, bulkhead connector or at the molex connector. Turn the ign sw on check the BROWN wires on one sides. of the Molex connector. If you don't power the on both side no need to go any further. Back to the ing sw. If it's on one side it's the Molex.
Here again with the ing sw on.
If you have power at the molex move onto the engine compartment connector 22 Brown. If you don't have it there it's in between there and the molex.
If you have power in the engine compartment connector 22 and not at the coil brown wire. It's the connector or the wire to the coil, If there is power at he brown wire at he coil. It might be the coil. Disconnect the The brown wire from the coil to be sure about the coil.
The bulkhead connectors are known to be a problem.
Coil is OK I have voltage there. Also made pickup from coil grounded and it is arcing.
Ohm reading at Distributor Pickup Coil has almost open circuit so I guess that is the problem.
Same thing happens to my 72 340 'cuda, no spark after sitting a few months.
If I take another distributor, plug it into the car harness and spin the shaft by hand once or twice it'll spark.
Car will start right up and restart fine for weeks.
No clue as to why.
Same thing happens to my 72 340 'cuda, no sparkA wqke after sitting a few months.
No clue as to why.
A siginal wake up call. I would have to theories. When spinning you are generating a magnetic field. Per Se. ( Bad Connetion somwhere?) The same as flasing the feild in an AC generator. It needs DC power for it to run.
Residual magnetism, also known as remanence, is the magnetization that remains in a ferromagnetic material after an external magnetic field is removed. This phenomenon occurs in materials like iron, where the internal magnetic domains do not completely return to their neutral state.
Sources of Residual Magnetism​
  • Magnetization Process: When a magnetic field is applied, the material becomes magnetized. Once the field is removed, some magnetization remains.
  • Material Properties: Different materials exhibit varying levels of residual magnetism based on their composition and structure.
Gauss is a unit of measurement of magnetic flux density. It was named after German mathematician and physicist Carl Friedrich Gauss in 1936. The International System of Units (SI), which uses the tesla (symbol T) as the unit of magnetic flux density.
1 tesla = 10,000 gauss
Degaussing
Degaussing
, or deperming, is the process of decreasing or eliminating a remnant magnetic field. It is named after the gauss, a unit of magnetism, which in turn was named after Carl Friedrich Gauss. Due to magnetic hysteresis, it is generally not possible to reduce a magnetic field completely to zero, so degaussing typically induces a very small "known" field referred to as bias. Degaussing was originally applied to reduce ships' magnetic signatures during World War II. Degaussing is also used to reduce magnetic fields in tape recorders and cathode-ray tube displays, and to destroy data held on magnetic storage.
When the key is in the on position (RUN) you should have battery voltage at the blue resistor wire. If not it is the wiring, bulkhead connector or at the molex connector. Turn the ign sw on check the DARK BLUE White trace wires on one sides. If you don't power the on both side of the molex connector, no need to go any further. Back to the ing sw. If it's on one side it's the Molex.
If you have power at the molex move onto the engine compartment connector 23 DBL white tracer. If you don't have it there it's in between there and the molex.
If you have power in the engine compartment connector 23 and not at the resistor connection. It's the connector or the wire.
If you have power at the feed or the resistor and not on the other side ( load side) it's the resistor.
There will be reduced voltage on the other side of the resistor (Load Side), that's what it dose.
The test light might not show it has power because it's lower power and completing the circuit. You might see a very dim light. Unplug the load side of the resistor wire is the best way.
If there is reduced power (9v all depend on the the battery state of charge) to the coil, It might be the coil.
If you have power there it doesnt mean you will get spark for ign. The distrubator triggers the coil. Meaning it turns the coil off, then the feild collapes and then you get spark. In short the distibator is the switch for the ground.
Points distributor gets its ground through the mounting surface. Take note of the ground of the third picture.
NO ground no GO!
I found it important that the voltage regulator must be grounded to the car from it's bolts into the firewall. I had an issue a year ago with my car not wanting to start. I tried to replace the voltage regulator and found the bolts to be too loose. When the back of the voltage regulator is not grounding to the car metal, then the car would not have power. I ended up installing bigger bolts into the firewall, and had to also drill the opening of the voltage regulator mount holes to be bigger to fit the larger bolts. It is a tight mounting now.
