Question on additional paper found with broadcast sheet
Moparhoosier2
Little help please? I recently bought a 71 Challenger and along with the 2 broadcast sheets there was this one. I have seen many broadcast sheets but never one of these.
I tried to load a pic but having problems doing it. Basically, it says
Chrysler Corporation on the top along with VEHICLE TRAVELER, then below it says
SEQUENCE NUMBER / VEHICLE ORDER NUMBER / VEHICLE ID NUMBER / VEHICLE DELIVERY & HAND
and then it has all the numbers below belonging to each heading
Any help? Sorry, I know a photo would help a lot.
Brian
DetMatt1
Welcome to the site from the Motor City! Pics are a must on this as your description isn't sounding familiar.
You have a vehicle traveler sheet. Is your car a special order car? I have seen these sheets for sunroof cars.
Moparhoosier2
I understand a pic would help. I will work on it. It just wont load for some reason. Thanks for the comments so far.
340challconvert
Parsippany, NJ
Welcome from New Jersey
Looking forward to seeing the build sheet. Sounds different. Something I have not seen.
340challconvert
Parsippany, NJ
challenger6pak's comment regarding seeing this sheet w sun roof cars triggered a thought?
Weren't the sun roof cars sent out for the work to be done outside the factory?
Was the "vehicle traveler" designation used for cars sent outside the factory for modifications (special order car) ?
Just a thought.
sdweatherman
I also would be interested in seeing this document - especially if it is sunroof related. If you don't have any luck loading the picture, send one of us a PM and you could email, text it, or instafacetubechat it one way or the other, and we can get it posted. ;-)
Moparhoosier2
I think I have the traveling sheet figured out and if so, I am extremely happy.
OK after researching the broadcast sheet, under the 1st row in section "A" the group package says 78. If you search the code for 78, it states
Formal Roof Package (71 only), Formula S-package. If you search what a formal roof package consists of, it is the S/E rear window - overhead console.
In other words, it is the rarer smaller rear window and an overhead console mounted on the roof of the interior of the car. After further research, I found that only 229 formal roof challengers were made which leads me to believe it might be as rare as a sunroof car? Thoughts? I knew the car had a small rear window which was more rare but I had no idea how much rarer it was. To think I have 2 broadcast sheets was already cool but to have a rare option like this and have a traveling sheet to back it up is just over the top. I'm stoked. Am I interpreting all this correctly?
aussiemark
Perth Western Australia
They only made 63 1971 Challengers with the sunroof so it wouldn't be as rare as them. Was the formal roof option work carried out outside the factory if it was this may explain this document.
sdweatherman
Thanks Brian for taking the time to post these. Very interesting - first time I have seen this kind of documentation. I am going to pass this info on to a couple of E-body enthusiast to see what they have to say about this info. The top of the travelers sheet looks just like the top of the broadcast sheet - but I noticed something a bit different. The first three numbers of the Vehicle Order Number is typically the Scheduled Production Date - three numbers - the first number is the month - 1 is Jan, 2 is Feb......A is Oct, B is Nov, C is Dec - and the next two numbers are the day of the month. What's interesting is that on the traveler's sheet, its W08 - hmmm. No W month. So its either a misprint or means something slightly different.
Moparhoosier2
Thanks for the welcome everyone and thanks for the input. I learned a lot over a short period of time from here as well as other sources. If I find out more, I will post it. Any additional input from others is certainly welcome.
Moparhoosier2
BTW,
I did go back and look at the travelers sheet about the "W" as you mentioned and yes, it clearly shows that. I have no idea why?
Moparhoosier2
It was actually in a stack of paperwork with receipts, an owners manual, a service catalog and parts diagram as well as the 2 broadcast sheets. I didnt even see them until about 6 months after I bought the car because they had stuck the 2 broadcast sheets and traveling sheet in the parts/diagram book and I started going thru the book for some recommended servicing. Bam, to my surprise there they were. The previous owner didnt even mention them to me.
sdweatherman
Brian,
I think the W is just a typo for A08 - notice the W and A are next to each other on the keyboard. If the scheduled production date (SPD) on your fender tag and broadcast sheet is A08 - then that is the most likely scenario.
Scott.
