Hi, I'm planning to install a new pair of Bilstein rear shocks in my 1970 Challenger. I looked at the shop manual on how to remove the rear shocks and it reads, it is necessary to remove rubber plug in luggage compartment to gain access to upper mounting bolt, in order to remove. I looked at my newer trunk pan which the second previous owner to me had installed. It doesn't have any plug holes.
It does have the 2 flat topped raised sections where the access holes should be. What diameter should the holes be? I found a Mopar parts supplier that has the metal plug and orange neoprene washer, which are 2- 1/2" diameter. Shouldn't the holes be smaller? If anyone knows the diameter or can measure the hole diameter please let me know. I've also seen pictures of the access holes with black rubber plugs in them, which is correct?
