rear vinyl trim
michael bucklew
posted pics of rear vinyl trim.. sent to shop to have vinyl installed. came back with different roof rail spacing--which is correct??? also what holds the las 11" of trim to roof rail to the roof have all correct clips in place---this is the original trim
michael bucklew
michael bucklew
which is correct---what keeps last 11" of trim in place--have all correct clips in place----ends are not flush to top
Juan Veldez
Nampa, Idaho
Image ending with 54 is the way I typically see it and is how mine is. When you say last 11" of trim, which trim, the roof rail trim or the vinyl 1/4 panel trim? The vinyl 1/4 panel trim has a clip like shown in ths photo that is hidden by the headliner a few inches back from the convergence of the two.Trim Clip.jpg
jsandy
Kansas City, MO
Is there supposed to be a washer included with these clips? Mine did not come with them. does the washer go under the nut or between the clip and the outside car surface?
michael bucklew
Image ending with 54 is the way I typically see it and is how mine is. When you say last 11" of trim, which trim, the roof rail trim or the vinyl 1/4 panel trim? The vinyl 1/4 panel trim has a clip like shown in ths photo that is hidden by the headliner a few inches back from the convergence of the two.View attachment 97666
that what i used, no washer---forward of that there is another clip--then there is 11" of no clips or pins just "floats" without being secured on the 1/4 trim to roof rail
Sail panel 71. You might be able to loosen the nuts and push it around front. maybe they pushed to much into the splice.
