Spring Problem
Gert186
Hi,
I have a Problem. I removed the harmonic balancer on my 340 Engine and was thinking that there is a safety ring inside. Inside the crankshaft but it wasn't. It was a Spring and I do not know where I can get this spring and which spring that is? Can somebody helps me please?
There is no spring in the crankshaft. That is most likely the remnants of a heli-coil used to repair the thread on the end of the crank. You should be able to have a new heli-coil installed or better yet, have a TimeSert installed if they make one that big. Timesert is more reliable but may not be compatible with the heli-coil thread. I don't remember the thread size of the harmonic balancer bolt off hand.
The other option would be to drill/tap the crank snout for the next larger bolt size that would clean up the hole. Not easy to do with the engine in the car, but doable.
Post up a pic of the bolt. It is pretty hard to mess up the threads on a bolt that size. What do the threads in the end of the crank look like?
