Glow Worm
Almost home yesterday and my car quit running. Everything was working as it should up til then. Had to hold the gas pedal to the floor to get the car to re-start, but after 30-45 seconds of idling it would die again. Took the air cleaner off and it looked like gasoline was puddling in the throttle bores of the carb. Put everything back on and tried it again and as long as the engine was running at high RPM's everthing seemed to be fine but when I let it idle it did the same thing again. The carb is a Edelbrock with a spacer. About 2 months ago I replaced the fuel pump and filter, and have driven the car several times afterwards without any problems, but the day before this happened I drove the car about 25 miles and it did sound like it was wanting to load up. Where do I start?
