Steering column key buzzer replacement
gregsgs@yahoo.com
Hi guys I am trying to replace the key buzzer in my 70 cuda. I have the wheel off the can off and the turn switch and the snap ring clip. I can't get the blinker column part off of the column any help would be great
burdar
IOWA
The buzzer itself isn't in the column is it? My 73 has the switch in the column but the buzzer is on the fuse panel.
the brg is on a splined part of the shaft & can get stuck there , a bit of penetrating fluid & pry up on the column body while gently tapping down on the column , make sure the nut is on the column shaft to prevent thread damage .
Only the buzzer switch is under there though as mentioned .
