On my 70 Barracuda with manual steering, I noticed if you pull up on the steering wheel, there is a 1/2 gap between the steering column and the crush can. I posted this problem before. Some people responded that the shaft may have collapsed, like it's supposed to. The other day I noticed that the top rubber seal on the steering coupler was bulging out when I pulled up on the steering wheel. It moves the same amount that the crush can does.. That led me to believe the steering column was still intact. Is there something in the steering coupler that prevents this movement? I know there is a small roll pin that supposed to prevent the shaft from completely coming out. I watched the rebuild videos done by Cuda Cody. I know there are some parts missing in the column (lock out plate, and snap rings) The plan is to convert to power steering. So If I have to cut the shaft, should I not worry about it?  Thanks
