Welcome to the site. Sign in over at the welcome wagon and let every body know what you got and what you need. We always need pictures of your car or project. Thanks.
Check out P-S-T who are one of our sponsors. 10% FEBO member discount too. They have tubular upper control arms with added camber and caster adjustment.
gccuda just saw your post ! I'm bigblock383@atlanticbb.net ( email ) I am in the middle of a upgrade to a complete after market front suspension I've put the Hotschkis upper controll arms in "adj" Hotschkis strut arms , Hotschkis tiered ends ,Hotschkis sway bar , Hotchkis pitman arm idler arm, mopar performance .960 torsion bars , Bilstine shocks , Right Stuff disc brake conversion new bushings thru out , Also put QA1 tublercontrol arms on bottom . Alingment shop trip , resulted in being told Tie rod on left side touching torsion bar Was not ever a problem before . If you or anyone out there can help me sort this issue out please feel free to chim in . Thanks in advance . And gccuda good luck to you keep me up dated on your upgrade , and I will you as well.
Hey Jerry Something isn't right . do you have the tie rods in from the top or the bottom ? and what steering box are you using . Is the lower ball joint the right one?
