Tubular control arms
I installed firm feel upper tubular control arms and they are much better than stock. The best thing is you have more caster for the alignment.
thanks just got back from the alignment rack. looks like I have to go to adjustables
1970 EBody
gccuda just saw your post ! I'm bigblock383@atlanticbb.net ( email ) I am in the middle of a upgrade to a complete after market front suspension I've put the Hotschkis upper controll arms in "adj" Hotschkis strut arms , Hotschkis tiered ends ,Hotschkis sway bar , Hotchkis pitman arm idler arm, mopar performance .960 torsion bars , Bilstine shocks , Right Stuff disc brake conversion new bushings thru out , Also put QA1 tublercontrol arms on bottom . Alingment shop trip , resulted in being told Tie rod on left side touching torsion bar Was not ever a problem before . If you or anyone out there can help me sort this issue out please feel free to chim in . Thanks in advance . And gccuda good luck to you keep me up dated on your upgrade , and I will you as well.
Hey Jerry Something isn't right . do you have the tie rods in from the top or the bottom ? and what steering box are you using . Is the lower ball joint the right one?
