what fluid in my 833-new rebuild
darryl
hey guys i have a freshly built 833 what fluid should i use atf-gear-motor oil.
S-S-P
Texas
My Chrysler shop manuals recommend ATF. I have had no problems using it over the years. I think there is a subtext about using heavier like 80/90 if you want less noise tho.
I am not a fna of using ATF , it is recommended in cold climates & in my daily driver I used a mix 1/2 ATF & 80/90w
S-S-P
Texas
Mix two oil weights? And it is regularly over 100 degrees (in the shade) here. It has been 106 just in the last week...
I was talking about the cold climate where I was living which regularly dips into the mid 30 below , in warm climates & summer use only I would use 80-90
