WhiskeyRebel
- Joined
 - Aug 30, 2019
- Messages
 - 30
- Reaction score
 - 17
Hi all, would appreciate some help sorting some wiring issues. Has anyone ever noticed the diagrams for the 72 and 73 Challenger are slightly different:
http://www.mymopar.com/downloads/1972/72ChallengerB.JPG
http://www.mymopar.com/downloads/1973/73ChallengerA.JPG
Specifically pins 12 and 24 seem to be swapped between the years (horn and low brake warning). The problem I am having is the M&H replacement harnesses are the same for both years and appear to be for the 73. The harness I have is also missing the gray wire from pin 20 that is supposed to go to the neg on the coil.
My symptoms: temp guage does not work, oil light is on, and no horn (tests fine). Ameter appears to work.
This black wire is coming from pin 24:
And also has this extra female plug off that wire:
According to the 1972 diagram, this should be a red/green wire to the horn. 73 says low brake sw which it appears to be. Just to check I jumped a wire from the horn to that femal plug. No horn still but the brake warning light came on. Seems consistent with the 73. I have no idea where this plugs into? Where is the low brake switch?
