Car sorta looks familiar. Bob, are you in SoCal?
Looks good!
If you are rebuilding the 340 or a 360 I’d go with a 4” stroke kit.
Just a simple way to get HP and TQ while being easy on valvetrain.
For engine building at the higher end look into QMP in Chatsworth. Brad started out working for Lambeck many years ago.
Hope to see you out at Willow Springs...
I am in So Cal. I'm guessing your initials are SW and you have more than a little to do with CPW?
Yes, I would like to run a stroker crank on the 340 rebuild. The piston speeds are elevated with the longer stroke, but making low rpm torque is good with the LA motor, given the poor valve train geometry. Of course, with more low rpm torque comes more low rpm HP, given that HP = (torque x rpm)/5252. I would also like to run a head with quench, versus an open valve pocket, and run a low deck height piston to have a zero deck height relative to the block to take advantage of the quench. I just don't know what aftermarket heads are available to do what I want and haven't investigated it much, yet. I have only seen that some of the dyno pulls with the Edelbrock heads haven't been too impressive.
Yes this is Steve.
Rob Troy?
Most aluminum aftermarket heads will get you quench. Air Flow Research seems to the latest and greatest in terms of quality and value in street like head.
What HP/TQ are you looking for?
It will be easy to build a 475-525 HP/TQ stroker with more power than your tires and chassis put down at Willow Springs.
I was able to dial in my quench with an off the shelf Scat stroker kit and simple Edelbrock heads. Mechanical cam with comp steel rocker for longevity and reliability.
Sharp eye. However, it is a 1951 Power Wagon, aka "Flat Fender Power Wagon" (FFPW) or "One Ton Civilian."Do I see a WC poking its nose end out of the garage?
I'm Dave. I don't even know a Rob Troy.
For the 475/525 combo, do you have any dyno pull data? What cam specs? What heads?
I haven't really thought about what power levels yet, or done much research, because I need to finish my brake conversion, do the five speed conversion (if/when I ever get to the top of Passon's waiting list for a five speed), and get my Power Wagon running. I suppose if I found a 70 E-body missing its original 340, I would get motivated and find the time, since there would be a home for the extra motor and the need to get the original motor done. I guess it's all a matter of priorities.
So, are you still running a carb on your Cuda?
